New Pump - No Start
Old Dec 28, 2007 | 06:20 PM
kaupca's Avatar
Car: 92 Camaro RS
New Pump - No Start
Put a new fuel pump in a 92 camaro. Also installed a new hose between pump and outlet with new clamps and a new strainer. There as about 6 gallons of fuel in the tank. When I turn the key I can hear the pump run. Tried a vacuum pump on the line under the hood and it sucked gas all the way from the tank. I need some ideas before I pull the tank again.
Old Dec 28, 2007 | 06:24 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: New Pump - No Start
its an electric fuel pump?
i had same problems with my car but i found out that i had the wires on backwards so it didnt pump.
but that was on a different type of car.
have you trued new fuel filter?
Old Dec 28, 2007 | 06:30 PM
kaupca's Avatar
Car: 92 Camaro RS
Fuel filter is new.
Old Dec 28, 2007 | 08:16 PM
Jason89RS's Avatar
with the feed line to the TBI disconnected, does fuel come out when you prime the line?
Old Dec 28, 2007 | 08:47 PM
kaupca's Avatar
Car: 92 Camaro RS
No fuel comes out of the disconnected line. I can pull it with a vacuum pump.
Went to supper. Came back. Now pump does not run at all now . No power to fuel pump relay.
I quit for today. Maybe blew the fuse.
I am about to agree with the last repair shop that worked on this car. It is possessed!
Old Dec 28, 2007 | 08:51 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
ignition module could cause the problem i think you can get them checked at one of the parts stores
Old Dec 29, 2007 | 12:55 PM
kaupca's Avatar
Car: 92 Camaro RS
Took tank back off and wires in connector at pump were reversed. Switched them and pump pumps off the car. Now have to put car back together. Thanks for the ideas.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
