LO3 to a LO5. Is it worth it?
Old Jan 28, 2008 | 10:43 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
After reading a lot of posts on the conversion, I am not sure if this is worth it.
My 305 locked up. I still have not torn it down to see what the problem is, but I cannot turn the motor over by starter, push start or hand.
I can get a LO5 from a 90 truck for 550 w/o injection. I am just looking for a cheap, quick fix and do not want to dump any more cash than I need to in the Bird. It is just my daily driver that has gotten way too much attention. If I just left it alone from the start, it probably would still be running fine.
Since the LO5 came from a truck, is it true that it is not a roller? If it is a roller, I would like to throw in a LT-1 cam.
Best bet for the ECM would be going to an EBL, right? Not sure if I want to go through the trouble of getting a PCM.
Need new injectors as well. Are the intake manifolds the same for LO3/LO5?
Should I just look for a vortec instead? Or should I just part it out?
Thanks!
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
