LO3 valve size?
Old Feb 15, 2008 | 07:59 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
LO3 valve size?
i used to have my cylinder head casting numbers handy but i forgot what they are...89 LO3 wanna know what number they are and the valve size...
Old Feb 15, 2008 | 08:05 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: LO3 valve size?
187 casting, 1.84/1.50 int./exh.
Old Feb 24, 2008 | 09:18 AM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Re: LO3 valve size?
cool thanks. any chance 1.94's would fit?
Old Feb 24, 2008 | 03:41 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: LO3 valve size?
Yes they would fit, but it's not worth doing unless you port them and grind the end of the swirl ramp down so that it's not visible from the port side. In stock form, the major flow impediment is the ramp end and the sharp-edge boss for the valve guide. The valve diameter is not.
Old Feb 24, 2008 | 08:25 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Re: LO3 valve size?
ok cool cuz my plan is to take those heads off my camaro, have them ported and install the 194 intakes and put them on my 350 S-10, for the bump in compression ratio...going from 65CC down to 58 will give a good increase not to mention the better flow from ported heads.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
