CFI stalling at stoplights
Old Feb 20, 2008 | 09:34 AM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Hey guys iv desided i cant afford to go carb atm so i was wondering if anyone could help me find out why my crossfire injection keeps stalling at stop lights after driving it for a few mins.. it does it in maby 5 min intervals or just when i stop andf go alot.. it doesnt do it on the high way tho it does sputter a little tiny bit on the highway here and there but no stalling. and when it stals i have to hold it Wide open throttle to get it started again, otherwise it jsut cranks. anyone have any ideads? anything would help thanks.
Old Feb 20, 2008 | 09:37 AM
tollers62's Avatar
Re: CFI stalling at stoplights
Sounds like you have a vacuum leak.
Old Feb 22, 2008 | 02:54 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Sounds like the trottle shaft bushings are worn. They create a vacuum leak when worn which creates stumble at idle and some driveability problems. Do a google search for "crossfire injection". There is a guy that re-bushes throttle bodies for around $70.
Old Feb 22, 2008 | 03:58 PM
tollers62's Avatar
Leaking throttle shaft bushings could very well be the vacuum leak you need to fix. I'd make sure it isn't something simple like a vacuum hose off. If you do decide to re-bush the throttle bodies, replace all the vacuum lines you can or at least the ones that are cracked and weathered.
Old Feb 23, 2008 | 12:39 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Yeah could be a vacuum leak , like-too much air . But it could also have not enough air , like a clogged IAC ...
Old Feb 24, 2008 | 09:29 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As everyone stated above I'd start with simple and replace all the vacuum hoses.CFI motors do not react well to a vacuum leak.Also check the top plate bolts that they are tight(as well as the TBI bolts).
Have you done a complete tuneup on her(to include a fuel filter)?And i would check the fuel pressure.GM has 10-12psi in the service manual but that is barely adequate.They perform better with 12 psi +(the site below gives instructions how to check adjust).
And as golden suggested check that both IAC motors are working properly.They can/will cause poor idle.
The throttle bushings are a problem as GM just installed the shafts in the main body and didn't uses bushings.The people you want to check are
http://www.crossfireinjection.net Tom and Jim are good people that do excellent work.They are also members of the Crossfire Forum which is an excellent source of info( http://www.crossfire.homeip.net )
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
