heated o2?
Old Feb 23, 2008 | 01:33 AM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
heated o2?
anyone try or have done a 3 wire heated o2 sensor swap on a tbi
Old Feb 23, 2008 | 12:35 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Re: heated o2?
These are usually used on OBDII gen cars . Why would you want a heated O2 anyway ?
Old Feb 24, 2008 | 01:48 AM
Car: 89 Iroc z
Engine: 350 carbed
Re: heated o2?
to run in closed loop
Old Feb 24, 2008 | 12:27 PM
golden's Avatar
Car: '89 Firebird
Re: heated o2?
Any car with an O2 sensor (1 2 or 3 wires) should run in closed loop .
Old Feb 24, 2008 | 09:49 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: heated o2?
'55427
It is an easy swap, and worth while if you are running headers and if NBO is sitting after collectors. In my case I run four wire NBO (AFS-75), the extra wire is used to provide true NBO ground reference back to the ECM. Separately powered relay is used to turn on NBO heater.
//RF
Old Feb 24, 2008 | 10:52 PM
Car: 89 Iroc z
Engine: 350 carbed
Re: heated o2?
thx for ur help RF ill try it out
Old Feb 26, 2008 | 09:26 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Re: heated o2?
I was told to run one when I did my 5.7 swap wiith headers...the car would run rich until it warmed up now it does better but I still have a few bugs to work out....Good luck
Old Jul 1, 2009 | 09:37 PM
JeepYJv8's Avatar
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
Re: heated o2?
I just tried te same thing!!! i have a 350 tbi in a jeep. i have headers and a good flowing exhaust so i ran a 3 wire heated...
It is not working. neither would a single wire! im lost im in the process checking wiring but these 02's are a pain in the a**.
anyone know if i need to run back to the ecm ground? in theory i shouldnt have to.. but who knows
Old Jul 13, 2009 | 06:46 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
Re: heated o2?
I switched to 3 wire heated since 2 wire stock would not stay hot enough to run closed loop at idle. This is common with modded motors with headers. Used a Delco AFS-74 with plug and play harness from TPI_parts on ebay. You just have to run the ground wire to a good ground (back of cylinder head) and supply SWITCHED power. I tapped into the gray wire on the fuel pump relay for power, so the o2 sensor is only powered when the car is running. Works fine, no problmes with closed loop at idle.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
