project 3 fitty
Old Mar 31, 2008 | 10:12 PM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
project 3 fitty
my dad owns a 1990 gmc with a tbi 350 and i have a 1989 305 Tbi camaro they both have around 85k miles on them,he says i can have his 350 as long as i give him my 305 and install it in his gmc. but hell its got me thinkin real hard how difficult is the computer and **** two hook back up, ... i would really love having the extra 40 hp alone not two mention the potential of a 350 and i would love two keep it TBI because going carb twice is going to cost some $$$ i think this project would be worth it in the end, i have been reading the important/useful305 to 350 and that helps i will probably get a tbi handbook as well and try two learn some more befor i atemp this project.
Old Apr 1, 2008 | 12:20 AM
ljnowell's Avatar
Re: project 3 fitty
You basically would have everything there you need. J
Old Apr 1, 2008 | 12:55 AM
Engine: Tbi 305
Axle/Gears: 3:73s
Re: project 3 fitty
yea i know i just want two learn more about tbi better two have the Knowledge befor i attemp two do this. i have taken motors out plenty of times just not tbi, whitch its rather simple when ya think about it however can be a little intimidating.
Old Apr 1, 2008 | 08:52 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: project 3 fitty
a blind retarded monkey could do this. as long as you keep track of all your wire hookups and make sure you don't brake anything it should be a complete "bolt-on" deal. I wouldn't worry about it to much. two things to consider now that I'm thinking about it are. Are the computers the same part number and do both vehicles have VATS? If the computers are the same then I believe all you have to do is swap chips if not then swapping the computer as a whole is no big deal either. If you have VATS and the truck doesn't then that could be an issue I believe.
Old Apr 1, 2008 | 02:59 PM
Engine: Tbi 305
Axle/Gears: 3:73s
Re: project 3 fitty
i will look into the "vats" thanks
Old Apr 1, 2008 | 10:08 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Re: project 3 fitty
the truck/van ecm is a '7747 or a '7746 and the car would be either a '8063 or an 8746. they wont directly interchange, however 89 9c1 caprice ecm engine settings can be put into the camaros ecm, and vice versa to the truck. the broadcast codes would be needed for both ecms and a short visit to moates.net should do the trick.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
