Should I get a new tb
Old Apr 28, 2008 | 09:17 AM
lingnfelterbird's Avatar
Car: 351 mustang and 1986 iroc
Engine: a small one
Transmission: th350
Axle/Gears: 9 inch
Hey guy I just bought a truck with ported votech heads, cam, 10:5:1 comp, jegs vortech intake, headers and full exhaust, tb spacer. The previous owner said he ran out of money to buy the tb so I wanted to know is the gain noticeable over the stock tb also it is tuned so I know I will need a retune just checking befor I drop 500 on a tb. Thanks Will
Old Apr 28, 2008 | 11:52 AM
Ronny's Avatar
Re: Should I get a new tb
consider doing a datalog to determine if you MAP readings are less than 90 at load WOT. that would indicate a restriction in intake flow. 100 MAP is atmospheric pressure and zero vac.
