89 2.8 mpfi --> 92 5.7 tbi
Old May 14, 2008 | 03:13 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i have the motor/trans in my camaro now... i tried the engine swap forum and got little help.
so, im coming here now. my fuel pump is not getting fuel with the v8 harness, i have to manually give it 12v power, which is fine, i dont mind that. it comes on when the computer comes on, just like my mpfi... after i rigged it.
next thing, when computer is on (and fp), and engine is started, its running like poop, but if i unplug the comp/fp it runs better, but still stutters. anyways, i need some advice on how to actually make my car run! lol. i have to floor it to get the car to go 2 foot
Old May 15, 2008 | 10:47 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: 89 2.8 mpfi --> 92 5.7 tbi
anyone? what do i need to do to my car to help change it from 2.8 mpfi setup to 5.7 tbi? do i need to get a separate regulator, do i need to change my fuses some? i know someone else here has done a 2.8 to tbi swap... i tried the engine swap and no one can help me either.
Old May 15, 2008 | 01:24 PM
92 RS Camaro's Avatar
Car: 92 RS, 02 GMC Sierra
Engine: 350 Vortech for 92, 323 for 02
Transmission: autos
Axle/Gears: unknown
Did you replace the fuel pump? A 2.8 pump will not support the amount of fuel that a 5.7 needs. Unless you installed a tank with pump from the 92 tbi car and all its fuel lines.
Old May 15, 2008 | 09:42 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
its getting too much fuel atm... after i turn off the fuel pump, it acts better, but eventually dies from no fuel.
have you done a 2.8 mpfi --> 5.7 tbi? if so, then i'll gladly change the fuel pump, but atm i think there is a better alternative.
Old May 17, 2008 | 08:49 AM
Transmission: autos
Axle/Gears: unknown
Are you running a FPR? Make sure that its set between 16-18 PSI. If you are not running a FPR, you will need one since direct injection pushes more PSI than a TBI can handle. Mine is a 92 that went from 3.1 to 5.7 and I have surging idle I am trying to fix. I had to change the pump to keep it from constatly flooding (thats when a budy told me I should have ran a fuel pressure regulator).
Old May 17, 2008 | 09:30 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
oo awesome, i'll go pick one up on payday anything else you have done (wiring wise, or anything else) to the car to make it run correctly?
Old May 18, 2008 | 01:03 PM
Transmission: autos
Axle/Gears: unknown
If you can find a 305 TBI harness for cheap, it might help. However, if you are familiar with mods your current harness deos not need to be changed. Other than the fuel pressure, did you change you chip set for your ECM? That would be the last thing I could think of. I am waiting for a ALDL cable to do datalogging so I can see what else needs to be done.
Old May 19, 2008 | 09:34 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i have the whole uncut 92 harness and computer. its only the regulator that needs adjusting right? anything else?
Old May 21, 2008 | 12:59 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i bought another regulator, and it still does the same thing... i think its a wiring issue between my 89' setup and my 92 setup.
anyone on this board go from an earlier car to a 91-92? anything anyone else can add? the car starts and barely moves, but its either getting way too much gas, or not enough. both injectors work and both wires work, they are just not both spraying...
i know its just a wiring issue, and maybe a fuel pump issue, but for the most part im sure its just a wiring issue, since the car will run w/ my current fuel pump.
anyone? i would really appreciate it! =)
Old May 26, 2008 | 09:27 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
Transmission: 700R4 by Monster transmition
Axle/Gears: Borg warner 3.08 posi
Oh my gosh i didn't think anyone else was dumb enough to do the same conversion as me. 89 2.8 to 350 with 91 TBI 305 wiring.
Did you solve the Pass key problem?
What gage cluster did you use? Did you rewire it?
Old May 26, 2008 | 09:44 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
I see what you did. You bypassed the wiring harness with a 12v lead to the Fuel pump. The problem is that there is a anti theft system called the pass key system. Its in the 89 and the 92 but its a different frequency (pluss GM rewired the 90-92 car.) What it does is look for a certain resistance from the resistor in the key to ok the computer to start the car. Once the comp has the signal it grounds itself out at 40 times a second (that way the thief couldn't just ground it to steal the car.) So when you bypass the wiring to start it it works but then it dies when the comp is supposed to take over the injecting.
I bought a pass key bypass box for about $30 from this one company. Ill have to get back to you on it.
The other thing is that the 90-92 gage cluster is wired differently than the 89 and the V6 vs a V8 cluster is as well. The 92 gages wont fit in the 89 dash right?
My dad helped me find the pin outs and rewired it.
so any questions just ask
-Rob
Old May 26, 2008 | 10:14 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
If it helps at all i have an 89' Camaro and i went originally to a 91 blazer 350 tbi then it was a junk motor (but it did run just burned alot of oil) then i went to a 88' Blazer 350 TBI and she runs good. If you want to ask me anything go for it i have some knowledge of my swap. THe only diff is it was easier for me b/c i had the 305 TBI originally.
Old Jun 3, 2008 | 06:33 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
well, the pump runs and the computer turns on if i ground out the relay (black wire)... but the injectors aren't wanting to spray, unless i give them +12v manually through the fuse block.
the pump turns on and the computer turns on when grounded, but no injectors >.<
any ideas anyone?
about that passkey... it should work just fine, i can manually start the car like i have been, which is crossing the hot and ground side of the starter -- i linked up 2 wires and a push-button starter so that i can turn the engine while not in the drivers seat... it will run, but very, very choppy with 1 injector at 12v.
thanks for any help
-Scott
Old Jun 5, 2008 | 10:51 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
anyone? help with making comp and injectors fire?
Old Jun 5, 2008 | 11:48 AM
hourang's Avatar
Car: 1992 Camaro RS
Engine: 5.0l TBI
sounds like your trying to bypass the vats the wrong way. u shouldnt be bypassing the starter and fuel pump and all that, bypass the vats the right way and go from there. if you want you can put in a computer from a TBI truck, no VATS, like is in my camaro now. it has no electric fan control though you have to have the a/c on for the fan to work. but im fixing that, got a new steering column with keys and vats module that im about to put in.
Old Jun 5, 2008 | 12:49 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
interesting... im just kinda curious as to why i need to bypass the vats now, vs when it went out in my 89?? it went out 1.5 years ago and i just used the push button starter... what changed between the 89 and 92? and... my security light is not turning on saying that the vats is messed up?
Old Jun 5, 2008 | 01:23 PM
hourang's Avatar
Car: 1992 Camaro RS
Engine: 5.0l TBI
not sure how you coulda started the car with a push button since the vats sends a signal to the computer to turn the injectors on. unless the 89 is different. your security light probably isnt wired the same. have you checked for any codes? the computer will not fire the injectors unless the vats tells it to or unless the computer has the vats programmed out of it.
Old Jun 5, 2008 | 06:27 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i will try and pull the codes, its just hard because the computer doesn't exactly have its own power given to it... it clears everytime i pull the plug lol.
Old Jun 6, 2008 | 08:31 AM
hourang's Avatar
Car: 1992 Camaro RS
Engine: 5.0l TBI
stop rigging stuff up man! lol if you want a good running vehicle wire it up like its supposed to be, disable the vats the right way if you have to, or diagnose what failed it in the first place, your just asking for trouble down the road, imo.
Old Jun 7, 2008 | 12:02 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
well the thing is... even if the key is in the "on" position, the computer should still light up (by itself)... and it's not even doing that. what would i do to give power to the computer?
the computer always got power when the vats was working, or when it was not...
Old Jun 9, 2008 | 08:31 AM
hourang's Avatar
Car: 1992 Camaro RS
Engine: 5.0l TBI
are your lights/radio coming on with the key in the on position? could be a bad ign switch or something.
Old Jun 9, 2008 | 07:13 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
yeah, my radio, interior lights, head/rear lights all come on... and when i turn the key to the "start" position, the seat belt light even comes on
Zane Story
Oct 8, 2015 12:40 PM
89bird2.8
Sep 18, 2015 07:46 PM
Springster
Sep 13, 2015 01:38 PM
rjcme
Sep 5, 2015 01:23 PM
