Please help me finish up this project
Old Jul 1, 2008 | 12:44 PM
Reklessoffroad's Avatar
I was referred to this board by a guy on another 4x4 website. Apparently, this is the site for TBI.
I am building a 89 Suburban as a 4x4 off road truck, and I am using the stock TBI. I have had the motor re-built with flat top pistons, decked heads, and a rv2 cam.
Here is the problem, the truck will not run, it seems like it is starving for fuel. If I take the vacuum line off of the MAPP sensor, the truck will idle fine, but you cannot put any throttle on it or it falls on its face. I put new injectors in it, a new throttle posistioning switch, fuel filter, I rebuilt the TBI 3 different times, and I tried a new MAPP sensor but that didn't work either. This is very frustrating as I am 2 years into this project and this is the last thing I have to do. Any help would be great as I am about to say screw it and go back to a carb for a bit.
Old Jul 1, 2008 | 01:37 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: Please help me finish up this project
Start with determining the fuel pressure.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
