1.6 roller rocker mix up
Old Jul 5, 2008 | 08:48 PM
notguilty_25's Avatar
Car: 89 camaro
i accidentally bought 1.6 roller rockers for the old style heads. i have the centerbolt. the current covers i have noticed are obviously 1/2" too short. but one of my rockers is hitting the baffle. are the baffles neccessary or is that a piece that can be removed, for clearance. if anybody has any ideas to make this work. give me a shout. thanx
Old Jul 6, 2008 | 09:11 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: 1.6 roller rocker mix up
If it is hitting, you are going to need to get rid of the baffle, or get a tall-valve cover. The OTHER thing you better check, is if you got rockers that are self-aligning. If you got non-self-aligning rockers, they won't work without running pushrod guide-plates.
Old Jul 6, 2008 | 07:27 PM
Car: 89 camaro
they are self alligning. i did make sure of that. ok so it should be good to go. i went ahead and adjusted them. so far it sounds good. im just waiting for the new valve covers to come in, that i got off ebay. so the baffle can come out...? if so i should be good to go. thanks for the info.
Old Jul 6, 2008 | 10:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
you will probably be ok, just keep an eye on the breather filter, and make sure it doesn't get soaked real quick with oil. I don't think it will be that big of a deal, especialy if you have tall valve covers coming.
MrPackstin
Oct 25, 2017 08:09 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
rusty vango
Sep 29, 2015 02:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
