Whys my O2 sensor so erratic???
Old Sep 16, 2008 | 04:34 PM
Killerzracing71's Avatar
IS it because its just a 20$ chepo, or what I have an EBL flash and on the WUD it shows 800mv then 4mv and back and forth, when Im in park and hit the gas it jumps up an down alot, in drive it does it occasionaly,
Dad said he tightened the O2 sensor up quite a bit from when we first put the motor in, what causes it
Im coming to the conclusion just a cheepo 02
Old Sep 16, 2008 | 07:38 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Whys my O2 sensor so erratic???
On a properly operating EFI vehicle in closed loop the voltage should sweep back and forth, the faster the better. That indicates the ecm is modifying the mixture and the exhaust oxygen content is reflecting the change.
Old Sep 17, 2008 | 03:33 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
https://www.thirdgen.org/forums/diy-...o3-lt1cam.html
92firebirdguy
Sep 1, 2016 07:53 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
GTAman
Sep 21, 2015 09:57 AM
