My Dyno numbers
Old Sep 29, 2008 | 04:21 PM
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
My Dyno numbers
My mods are in my sig.
RPM x1000 hp ft-lbs
3.10 61.86 108.15
3.20 143.05 234.78
3.30 148.34 236.09
3.40 152.81 236.06
3.50 156.56 234.94
3.60 158.66 231.46
3.70 163.56 232.18
3.80 167.79 231.91
3.90 169.75 228.59
4.00 172.29 226.23
4.10 175.65 225.01
4.20 177.73 222.26
4.30 176.82 215.97
4.40 177.01 211.29
4.50 178.11 207.88
4.60 178.44 203.73
4.70 178.40 199.35
4.80 177.82 194.59
MAX: 4.80 178.44 236.09
MIN: 3.10 61.86 108.15
Old Sep 29, 2008 | 04:41 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: My Dyno numbers
Shur is better then stock
Im convinced that with the correct fueling and proper tune you can make 200rwhp, with your combination.
What fueling mods and tuning have you done yet?
Old Sep 30, 2008 | 09:53 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Re: My Dyno numbers
RPM x1000 hp ft-lbs
3.10 61.86 108.15
3.20 143.05 234.78
3.30 148.34 236.09
3.40 152.81 236.06
3.50 156.56 234.94
3.60 158.66 231.46
3.70 163.56 232.18
3.80 167.79 231.91
3.90 169.75 228.59
4.00 172.29 226.23
4.10 175.65 225.01
4.20 177.73 222.26
4.30 176.82 215.97
4.40 177.01 211.29
4.50 178.11 207.88
4.60 178.44 203.73
4.70 178.40 199.35
4.80 177.82 194.59
With basically the same setup I made 216 rwhp, 266 rwtq, get to tuning!
I had
LT1 Cam
Edelbrock Performer EGR Intake
Ultimate TBI
1/2" TBI Spacer
14x3 Open Element
3" Cutout before cat
SLP 1 3/4" Headers
T-5 w/Aluminum Driveshaft
Full MSD Ignition
Prominator
What did your AFRs look like? Did you mess with timing or fueling at all? Good luck and there's definitely more in her!
Old Sep 30, 2008 | 11:37 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: My Dyno numbers
Give that thing some more fuel, I see about 13.7:1 and it should be down on that dotted line at 13:1 or possibly lower.
Old Oct 1, 2008 | 09:57 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Re: My Dyno numbers
Ah I must not be able to see the dyno chart at work .
Get it back on a dyno and get more fuel into it
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
