Update on the fogger tbi setup
Old Oct 24, 2008 | 03:09 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Just figured i would post some new photos. Orginally i had the bottle between the two passanger seats. However i didnt like the way it looked so i patched the holes i made and i moved it to the trunk. I mostly just use the spray for the track so its not like I need to turn it on/off for the street. Anyway. I got the bottle powder coated and i think this setup looks much cleaner.
Old Oct 27, 2008 | 03:35 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Re: Update on the fogger tbi setup
WHERE DID YOU GET YOUR KIT?!!!!!!!!!!!!!!!! I WAS WANTING A FOGGER NOSSLE TO PUT IN A TBI SPACER AND I WANT A COMPLETE KIT. I CANT FIND IT ANYWHERE
Old Oct 27, 2008 | 04:31 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Nice TBI hat! Is that custom. Love the minimalist approach to the engine bay, but no A/C in FL must suck. No emission concerns out there? I got a bottle from my old TPI kit, but need to make everything for TBI. I like your approach over a plate. The old TPI I had was two foggers, but one should be just fine w/ less plumbing with the proper jets.
Are the injectors safe being downstream of the NOS?
Old Oct 28, 2008 | 08:30 PM
Car: 1991 Z28
Engine: SBC
Yea no the a/c will be going back in shortly...i had to fix a rust hole in that area so the evap box needed removing haha. Yea the tbi hat is custom and the kit works great. I did make sure i shield injector's harness with some plastic wire loom just to protect it...i though raw fuel might hurt the wiring. The kit is actually from a 5.0 mustang. I just had a friend make me the hat and got the right jets...works great.
Old Oct 28, 2008 | 09:08 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Engine bay looks good but get rid of the diverter valve on the pass side valve cover. It looks like poop. It's good to see a fellow Floridian Kicking *** with TBI.
Old Oct 29, 2008 | 07:52 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
That's not the diverter, it;s the heater control valve. I'll try to post a pic of my solution to that one. Basically, I put a 1/2 ball valve on the intake rear passenger water outlet. Then I ran a sort preformed hose from there to the heater core. Last, I ran one single hose from the core outlet straight to the radiator. At least then I can close the valve if the heater core goes or in the summer to keep heat out of the cabin.
db057
Apr 28, 2019 07:45 AM
86Firebird86
Dec 26, 2015 07:21 AM
Ranbo108
Sep 9, 2015 12:20 PM
rsrookie
Sep 5, 2015 07:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
