Fuel/TBI Newbie Questions
Old Nov 12, 2008 | 09:37 PM
dford's Avatar
Hello,
Had a new Fuel Pump put in but the shop said there was no fuel filter? 1983 Z28 Cross Fire 305 - Totally stock. Very cool but I haven't got a repair manual yet. (It's on the way)
Are the two TBI supossed to fire like sprinklers or have a constant misting?
Whats the best way to (DIY) clean the TBI units? Thanks.
Dan
Yakima, WA
Old Nov 12, 2008 | 10:27 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: Fuel/TBI Newbie Questions
they should spray like a cone out of the injectors.
Old Nov 12, 2008 | 10:47 PM
dford's Avatar
Intermitent or continuous? They now shoot like 2 rainbird sprinklers... chu...chu...chu.
Thank you.
Old Nov 12, 2008 | 11:10 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
never had a CFI vehicle, but on the regualr Rochester TBI units (like mine) it sprays intermitten at idle. Almost like a "click click click". As you roll on the throttle and the engine demands more fuel, the injector pulse widens and they pour more in.
If you think about how it works, its simple. The fuel pressure on these cars isnt supposed to really change. That in mind, the way the ECM controlls mixture is by controling how long the injectors are open / closed.
I read somewhere that on a TBI vehicle, all factory, the injectors can go static (completely open) above 4500RPM at WOT. Not sure if its true.
Old Nov 13, 2008 | 09:20 AM
dford's Avatar
Thank you. Sounds right.
What is the best way to DIY clean the TBI units? Spray?
Dan
Old Nov 13, 2008 | 12:10 PM
Ronny's Avatar
Best way is to send to FICINJECTORS. Look on corvette forum and they have a video posting of the clean/rebuild process on a TBI vehicle. Like $35 each. All you can do is clean pindle and that is not sufficient.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
