Where is ESC located on 1991 RS 5.0?
Old Nov 17, 2008 | 08:55 PM
Tims91RS's Avatar
Where is it located on the car? Will it cause idling issues if it is not swapped when doing a 5.7 swap?
Old Nov 18, 2008 | 11:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Where is ESC located on 1991 RS 5.0?
The ESC module/filter is located behind the relays near the brake booster. Flat plastic box about 4 x 4 " square and an inch thick. Probably has the three letter code HKM on it.
Most likely not causing the idling issue. Knock counts are ignored when the engine is at idle. Idle meaning not moving and the proper RPM.
RBob.
randywyatt200
Sep 9, 2015 04:27 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
