Fuel pressure question
Re: Fuel pressure question
The hot setup is to remove the stock regulator, radius the internal openings, install a blockoff plate and an external vafpr (eg: aermotive 13301.)
As I understand it, the TBI injectors are good to at least 43.5 psi.
Just be careful with the fuel pump choice, as the injector pod will only flow so much fuel.
yes
bump up then lurkIf you need sell cheap wow gold,you can buy wow power leveling on the website: buy wow gold, cheap WoW Power Leveling, sale wow Gold, 1-80 lvl wow power leveling, wotlk WoW Gold,
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
