I just purchased 2 fel-pro intake sets ms90314-2 and ms93317. the ms90314 is for a 4 barrel set-up. i have tbi and use the 93317, will the front and rear intake seals in the 4 barrel set-up work for my 305 tbi block set-up. i dont want to use only the black rtv to seal up the front and rear. but that is what my set-up calls for. i would not mind using the gaskets and a little bit of rtv on the gaskets if they will work. any advice would be helpful.
i never use the seals and only use blk rtv for the front and rear as well as a little around the h2o ports on both sides of the gasket and a small stream from the h2o ports to the front and rear. Just let it set up for a bit to get tacky before putting the intake on. Then once bolted on i go back and wipe up the excess rtv for a clean look
