i have some questions
Old Feb 22, 2009 | 06:52 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
ok,so ive always heard LO3 run on the lean side from the factory,well ive also removed the AIR system.
so that mean my car is gonna be runing more lean now?
what is stock fuel pressure,PSI?
how much should i raise it?
whats a good not to pricey regulator?i saw somewhere bout putting a washer in the stock one would raise it,this safe or true?
will this make it a good bit peppier?
Old Feb 23, 2009 | 12:37 AM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Re: i have some questions
bump
Old Feb 23, 2009 | 03:55 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
These cars run rather rich from the factory. You can add some SA.
Put the air sistem back on, the only thing that happens by removing it, is your cat no longer reduces the toxic gasses as it is supposed to.
11.5-12.5 psi
Use the search option and read the stikies to find out how to make it peppier.
Old Feb 24, 2009 | 12:17 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
What you probably heard is that lo3 fuel pumps are garbage, which is true.
Old Feb 24, 2009 | 01:15 AM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
well that wouldnt surpise me,pretty much eevrything factory on these cars are garbage.
Old Feb 24, 2009 | 01:31 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just so nobody gets the wrong idea here, LO3 fuel pumps are "garbage" when it comes to trying to use them to feed engines of significantly higher-than-stock performance.
For stock or near stock setups, they are fantastic. Quiet and damn near bulletproof.
Old Feb 24, 2009 | 01:02 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
My stock pump just took a bullet, putting in another today, Got the TPI version so if more mods come along dont gotta replace the fuel pump, just the Pressure Regulator
I wouldn't say everything on these cars are crap Just some bad designs but thats with every car.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
