Aldl interface cable questions
Old Feb 25, 2009 | 05:11 AM
chevyracer8262's Avatar
I have found several different schematic for building your own interface cable, how do i know which one would be th best for me and work with my applications?
what I have is an 1227747 ecm with the asdu prom id. here's the different cable schematics i found. Which one the right one for me?
http://winaldl.joby.se/aldlcable.htm
or this one
http://www.home.aone.net.au/~techedge/vehicle/2tran.gif
Any help would be greatly appreciated
thanks,
Old Feb 26, 2009 | 11:06 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Aldl interface cable questions
Either one is fine for a TBI computer. If you use the first circuit do not us R3 or R4.
Old Feb 28, 2009 | 03:03 PM
So I don't need to use the one with the seperate power? What about using the one with the 2 transistors? It has the pinouts for a DB25 parallel port which my laptop has, would this configuration work? Has anyone tried this one?
Old Mar 1, 2009 | 09:54 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
I would recommend at least starting with the separate power to get it working. Then you can try changing it to using power from the serial port to see if your laptop will support this. I do not think tbi requires the 2 transistor. Will work fine with tbi but the second transistor is used for other ecm types that need to be sent characters to change mode.
The 25 pinout is for a 25 pin serial port, NOT parallel port. The 2 transistor with 9 pin serial port is what I use.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Caspar
Jun 19, 2016 11:19 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
