Mods and Stock Fuel Pump.
Old Apr 8, 2009 | 11:26 PM
Z28XTC's Avatar
What will my car feel like and run like if it's on stock fuel pump with mods in my sig? Sometimes when I stomp on it it just dosent wanna go. Is this cause of Fuel Pump? I have not fitted IROC fuel pump yet.
Old Apr 9, 2009 | 09:41 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: Mods and Stock Fuel Pump.
Hook up a fuel pressure gauge so you can see it from inside while you're driving.
If the pressure drops when you boot it, more so up higher revs - it's time for a bigger pump!
Old Apr 9, 2009 | 10:31 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I think, with the stock injectors you will need over 21psi at WOT to cover the fuel demand of your set up.
AFPR, better fuel pump and tuning is a must at your level. EBL would be The perfect upgrade to make the tuning effective, easy and fun.
To check if the FP stays steady under load, I fit the FPgauge under the window wiper.
With a little tune your engine+mods should run fine even with the stock fuel pump, for gentle driving, but careful as you smash the trottle it will go out of fuel and knock like hell.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
