305 and 350 tbi fuel pump
Old Apr 18, 2009 | 11:15 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
i looked up the fuel pump for the 305 tbi in my camaro and looked up the fuel pump for a 91 silverado 350 tbi and i noticed that the fuel pumps are the same. i was under the impression that the 350 used a higher flow fuel pump. does this mean that i can swap in a stock 350 and not have to change fuel pumps. if i swap engines i really dont want to go through the process of changing out the fuel pump as well. its an extra expense and a pain to pull the tank, as we all know.
Old Apr 19, 2009 | 09:52 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: 305 and 350 tbi fuel pump
Your stock (?) fuel pump is probably getting old & tired (hmmm, sounds like me).
It MIGHT be able to feed the 350, but it might not. Just hook up a fuel pressure gauge so you can see it while you're driving. If you can punch it and not see an appreciable pressure drop you're probably OK.
If you've done anything to the 350 though, your fuel requirements will probably outstrip the stock pump. Especially if you're moving into larger injectors, or trying to overcrank the pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
