LO5 head question
Old May 1, 2009 | 06:58 PM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
LO5 head question
I have a L05 in 92 Roadmaster Wagon I wanna do the LT1 cam swap.The ultimate TBI mod ,9C1 injectors and computer are waiting to be installed so my question is with out going with the vortech heads which are the best stock heads to use? year, make and model also I need to run stock intake manifold do to the cowl overhang.
Old May 5, 2009 | 01:32 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Re: LO5 head question
really depends on what you would like to do with the engine. If its in a wagon i would want a nice low end torquey motor which tbi heads are fine for. They will provide great performance below 4500 rpm. If ported they flow surprsingly well and can make some good numbers. Paired with an lt1 cam, should be a good performer if your on a budget.
Old May 6, 2009 | 04:21 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Thanks for the info I kinda figured the TBI heads would be good enough for a daily driver just looking to get a little more out of it that's why I'm doing the cam swap.Also picked a Holley TBI at the local pull a part this past weekend for 23 bucks so I'm goona run that instead of the UTBM.
Attached Thumbnails LO5 head question-img_1000.jpg   LO5 head question-img_1001.jpg
Old May 6, 2009 | 07:35 AM
Car: 1991 Z28
Engine: SBC
nice find, yea the cam swap will make a nice addition to the tbi heads. Like i said, if you want some good performance out of the heads for the $, enlarge the intake side and exhaust side, polish the exhaust side port. Fairly easy and cheap.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
