Fuel Everywhere!!!!
Old May 7, 2009 | 10:27 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Fuel Everywhere!!!!
So I got this new air cleaner and was having a hard time putting it on (https://www.thirdgen.org/forums/tbi/...aner-swap.html). I could not get it on with the stock stud because then my throttle cable would be in the way. So I had to change the stud. I have no clue about TBI what so ever. So I just took out the top part with the torque head screws on it. Well on the tower thing (in the photos) fuel started pissing everywhere. I had to get paper towels to stop it from getting on my butterfly valves. But I mean it went everywhere. It was fuel but smelled stronger than normal fuel I almost fell on my *** when I went up to sniff it. This was a few days ago and my car port still smells. I have not had the car running yet so I couldn't tell you if it was flooded or not. I just want to know what happened???????
Attached Thumbnails Fuel Everywhere!!!!-2897_102743170708_511595708_3052896_6317689_n.jpg   Fuel Everywhere!!!!-2897_102743175708_511595708_3052897_306660_n.jpg   Fuel Everywhere!!!!-2897_102743180708_511595708_3052898_2023340_n.jpg
Old May 7, 2009 | 02:44 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Fuel Everywhere!!!!
well, you removed the 'plug' from a pressurized line - that's what you get.. should have looked into that more before removing that stuff. next time you do it remove your gas tank cap, pull the fuel pump fuse and crank/run the engine till it dies. then there should be a lot less fuel (pressure) in the lines / passages of the tb.
Old May 8, 2009 | 01:33 AM
Car: 1991
Transmission: 700
Thanks man!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
