scored a 350tbi, but a little lost
Old May 16, 2009 | 03:47 AM
91rsinnm's Avatar
Car: 91 rs
Engine: 305 tbi
Transmission: t-5
I ended up finding a 350tbi. the deal is that the alternator sits on the left where the ac compressor thing was sitting on the stock 305. so what im wondering is will they switch over. will i have to rig the wiring and ac lines.
Also where do you guys think i should get the 350chip from.
Old May 16, 2009 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: scored a 350tbi, but a little lost
Use all of the front dress items from your original engine. This way it all bolts back together stock. For a chip try one from a '90 Caprice with the L05 engine.
RBob.
Old May 16, 2009 | 01:13 PM
91rsinnm's Avatar
Car: 91 rs
Engine: 305 tbi
Transmission: t-5
thanks man, thats what i was thinking of doing, just wasn't sure if i could just switch over the accessories or if i needed to switch over the whole assembly. For the record it had the power steering on the top right, and the alternator on the top left running with 2 belts. therefore, would this be an older block. any idea how to tell the year of the block.
Old May 16, 2009 | 05:30 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Is a two piece main rear seal or a single? Take a look at the block casting numbers to the right of the rear of the china wall. Older blocks will also have a four digit casting date in that area, but it is not precise since Gen I blocks span decades. Also, on the front left head block deck surface (just before the head) there should be partial vin and engine RPO designation stamped. With all four bits of information you should be able to determine build date of the engine.
//RF
Old May 16, 2009 | 08:15 PM
91rsinnm's Avatar
Car: 91 rs
Engine: 305 tbi
Transmission: t-5
Well i found the numbers but it turns out it a 305. a little bummed but for getting a good motor for free i cant bitch too much. Atleast i can get my car running again. I'll just buy a 350 block and build that as I can. thanks for the help though.
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
RedLeader289
Sep 23, 2015 06:50 AM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
