new to site
Old May 19, 2009 | 11:47 PM
-DIABLO-'s Avatar
new to site
hi there im a proud owner of a 1991 camaro rs 305 tbi and a 1996 trans am
i bought the camaro two weeks ago i paid 800 cause supposibly it had blown head gaskets cause it was overheating the problem was the water hoses on the back of the block were torn so heres my ?
can i run lt headers without problem?
wich cam can i run?
can i take the egr crap off?
what do i need to do to convert to carb?
does a lt1 cam work in 305?
thanks in advance
Old May 20, 2009 | 12:28 AM
327Chevy's Avatar
Re: new to site
Welcome to thirdgen.org
Shorty headers are easier and give better ground clearance. It is possible to run LT's but I believe you will end up with custom exhaust and most likely not be emission compatible.
You will need to be more specific about your intentions with the car for a cam recommendation.
EGR stuff is needed if you plan to pass emissions. You will probably also get the check engine light if you remove the stuff.
There is a tech article here on converting to a carb. Go to thirdgen.org main page then click technical articles. There will be many articles. Again, this will probably keep you from passing emissions.
There is a sticky at the top of the TBI forum all about LT1 cams. Actually, reading through several of those stickies would be a good idea.
Old May 20, 2009 | 09:32 PM
-DIABLO-'s Avatar
Re: new to site
i dont care about emissions,i want a nice lope cam and good power how much power can these 305 handle with all the boltons and cam
which gears are recomended for a five speed rs and also wich clutch
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
FueledSoul
Sep 30, 2015 09:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
