new to fuel injection, running lean. (sorry i dont know what i'm looking for)
Old Jun 22, 2009 | 03:58 AM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
first off, sorry if this has already been discussed but i have no idea where to look or what to look for to help me. i've gotta 91 rs 305 tbi. someone put an exhaust and chip in the car b//4 me and it ran good but smoked (valve uide seals) so i had everything apart changing thoes and decided to 86 the egr stuff. since i've done this shes been running lean, still idles smoth but no take off and it dies from time to time. i modded the fpr and diddnt help, i rebuilt the tbi, and changed the injectors (factory size) and still nothing. does anyone make a plug and play programmer for theese cars or is there a way of not having to burn a new chip? any advice is appreciated.
Old Jun 22, 2009 | 04:22 AM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
Re: new to fuel injection, running lean. (sorry i dont know what i'm looking for)
I have a simple solution to your problem..... put the egr back on! It's hurting you more off of the motor than on it. The cool thing is, you didn't have to take it off, if you were into tuning, you could have turned it off. Check for Vacuum leaks. Missing hoses, stuff like that it can cause you to run lean.
Old Jun 22, 2009 | 09:35 AM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
the other reason for removing it which i failed to mention earlier, someone hacked out the cat when the exhaust was installed so it wasnt really doing anything anyway (so i thought) and i'm more into the oldschool look of not having anything cluttering up the motor. anyway, there are no vacuum leaks anywhere that i've found so far, anything else that could possibly fix it (other than the obvious return it to stock)
Old Jun 22, 2009 | 09:38 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Sounds more like a hardware problem - start checking important things - fuel pressure being #1. Ignition #2. Then everything else. It should still run quite well (not dying and gutless) with the factory tune.
Old Jun 23, 2009 | 04:55 PM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
so, update. i found out that the 33 code wasnt for the o2 sensor like i was told but for map low vacuum and since i had access to another map i swapped em out to see what would happen, now it starts lean, ritchens up and goes back and forth violently, still no power and i cant use the a/c because it bggs it down even more.
Old Jun 23, 2009 | 06:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not being related to DIY_PROM, moving to TBI board.
RBob.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
