Rubber Fuel Line Hose at filter OK?
Old Jul 9, 2009 | 12:43 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
As expected, my fuel filter was a rusted mess when I went to replace it. I ended up cutting the line on either side of it.
With only 9-13 PSI, is it alright to use standard rubber fuel line hose the rest of the summer until I get under there and replace all the lines with original ones?
Were talking about 5-8" max on either side of the filter.
Old Jul 9, 2009 | 01:47 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Rubber Fuel Line Hose at filter OK?
SAE 30R7 is rated up to 50 PSI working fuel pressure (for sizes under 3/8"), but a safer choice would be SAE 30R9 hose good up to 150 PSI.
TBI runs at about 15-20 PSI at filter. Just be aware that it is common to install TPI pumps in place of TBI rated pumps. TPI can push pressure well above 50 PSI when deadheaded.
//RF
Old Jul 12, 2009 | 08:05 PM
vt89rs's Avatar
Car: 89 Camaro RS, 79 Camaro z28
Engine: 385 stroker
Axle/Gears: 3.23 posi borg warner
I’ve had to do this to a few of my cars being in Vermont. Winters suck, anyway, ya just go get the rubber fuel hose that's meant for fuel injection, because it does make a difference. I’ve blown apart regular rubber hose before and it's not fun
Old Jul 15, 2009 | 12:44 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
same here losts of rusty lines in my area,use fuel injection hose. also i double up the clamps.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
