speed limiter??
Old Jul 29, 2009 | 02:12 PM
FxsX24's Avatar
Car: 1994 s10
Engine: 283
Axle/Gears: 4.10, one spinner
speed limiter??
i have a 283 tbi in my s10, i think i have the 7427 pcm in it (not sure what prom, i had a pocket of them till it ran right)
i cannot get the truck past 100mph, i have more rpm to go (kicks back at about "6k" (i say "6k" since the tach is 33% off since it is set for v6) the engine is at "5500" when im at 100 and it limits like my jimmy does ( hits a limiter and slows you down)
1994 MY computer, 94 4l60e and 4.10 rear gears on 205/75/r15 (DRAC is set for that rear and tires)
Old Jul 29, 2009 | 02:38 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: speed limiter??
find the vss wire going into the cpu and put a troggle switch on it. thats your speed sensor wire and just cutting it will make the check engine light stay on if u put the switch on it u will be able to bypass it and still switch it back to make the light go off.
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
