The correct fuel pump?
Old Aug 4, 2009 | 02:28 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
Per some advise I received on here I decided to take my Walbro 255 lph back and get a Walbro 190 lph. I bought it at Summit Racing and they only had one 190 and it was for a Mustang. The guy said it would work w/ an LO3, but I wanted to make sure. Please check out the link and let me know that this is compatable.
http://www.summitracing.com/parts/VPN-GCA710-2/
Old Aug 5, 2009 | 03:20 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: The correct fuel pump?
Originally Posted by Shakermaker05
Per some advise I received on here I decided to take my Walbro 255 lph back and got a Walbro 190 lph. I bought it at Summit Racing and they only had one 190 and it was for a Mustang. The guy said it would work w/ an LO3, but I wanted to make sure. Please check out the link and let me know that this is compatable.
I am running a 255lph Holley ( same pump different stickers ) in my 88' bird. I have a mostly stock motor that runs better than it did with the 21yr old pump. I have been told also that it will or would cause a problem. So far i have had it in for the last 6 months w/out any problems. I know for the most part the FPR will keep the pressure where it should be, even w/ the higher flowing pump. I don't know if the mustang pump is interchangable though.
Old Aug 5, 2009 | 03:28 PM
Car: 1991 RS
Engine: 305 LO3
Yeah, I really didn't know what to make of that either. I had a handfull of guys tell me that it would work fine and some tell me that it would cause problems. I just figured I'd go the safe route w/ the 190lph.
I'm pretty sure this Mustang pump will work w/ the Camaro. Same size & shape as the 255. It just hacks me off I'm gonna have a Mustang part in my Camaro : (
Old Aug 6, 2009 | 12:31 AM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I am running a Walbro 190LPH pump from a fox body in my truck right now with great results. Plus when I can finally afford the rest of my HSR parts it will be fine for that too.
Old Aug 6, 2009 | 09:29 AM
Car: 1991 RS
Engine: 305 LO3
Well if you can run it in a truck I'm assuming you can put it in a Camaro too! It's good to hear you have good feedback on this part. I can't wait to get it put in! Thank you for the help!!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
