fuel problems...
Old Aug 23, 2009 | 05:20 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
fuel problems...
Im having some fuel problems with my car.. I just swapped the motor from 5.0 to 5.7, the day i attempted to start the car i ran it for about 20 minutes, pretty much at about 2000 rpms just tryin to break everything in, checkin for leaks, got it timed n stuff. Well since then i havent been able to start er up again. Im not getting any fuel to my injectors, TBI by the way, i changed the filter, pulled and cleaned the injectors, changed the pump relay, changed the little fuse by the battery, i even dropped the freakin gas tank and changed the pump. Anyways, it still will not start. Its not out of gas, is there anything else i need to check, maybe somethin electrical? Im kinda at a point where i dont know what else to do. Anything input is much appreciated, thanks
Old Aug 23, 2009 | 10:20 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: fuel problems...
Maybe a VATS problem?
Old Aug 23, 2009 | 10:44 PM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
spend less time at CiCis and more time with your
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
