Fuel help please!
Old Sep 27, 2009 | 12:11 AM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
Fuel help please!
Ok, swapped 305 for 350, 89 RS. Anyways I cant get the car started without Carb Cleaner, it just will not start! but once we squirt some b12 in the TB it fires right up, runs and idles great. Now ive replaced the fuel filter, pump, both injectors, and bought a new TB, i can only assume that maybe it just has some old gas in it? Would old gas keep it from starting? Its been sitting for about a year, maybe a year and a half. Is there anything else that may keep it from starting? I really appreciate any info
Old Sep 27, 2009 | 02:36 AM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: Fuel help please!
You have a bad fuel pump relay, the fuel pump however get backup power from the oil pump switch once pressure is built so once you get it running on carb cleaner the switch is powering the fuel pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
