Screwy MAP readings?
Old Oct 13, 2009 | 05:39 PM
TXBowTie40's Avatar
I've been doing some datalogging since the weather turned colder, and noticed something yesterday that must have escaped my attention:
My Manifold Pressure reads 10-12 volts, depending on how I am driving, using TunerPro RT.
I thought from reading on here that the MAP sensor was a 0-5 volt device?
Any thoughts on the completely out of whack MAP readings?
For what it's worth, my vehicle is a 1993 K1500, 350 Vortec, Edelbrock Performer RPM intake, Holley TBI adapter, stock TB with 61lb injectors running at 20psi, ZZ4 cam, '7427 PCM, $0D code.
Am I imagining things, or should the voltages from the MAP sensor be reading somewhere between 0 and 5 volts? The truck starting running very oddly when the weather changed, which I attributed to possibly a change in the fuel blends.
Now I'm wondering if the MAP sensor is the culprit.
Old Oct 13, 2009 | 08:08 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: Screwy MAP readings?
What program are you using? Sounds like a definition problem.
Old Oct 13, 2009 | 09:00 PM
TXBowTie40's Avatar
I'm using TunerPro RT, XDF is 0Dv1_02, bin is a slowly tweaked over the summer BJLH
Old Oct 13, 2009 | 09:30 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Agree - MAP operates from 5 volt supply rail and its output range is between 0.5 and about 4.8Vdc.
//RF
Old Oct 14, 2009 | 05:30 AM
TXBowTie40's Avatar
By definition problem, are you referring to the datastream definition file? I can't recall if I downloaded it from the TunerPro site or from Moates.......I will definitely look into that, though.
Old Oct 14, 2009 | 10:43 AM
TXBowTie40's Avatar
Thanks guys, I found a different datastream definition file and am using it now. It shows the engine idling at 25 KPa, which is pretty good I thought. I read somewhere this morning that the ZZ4 cam has good idle vacuum....now I can tune better I hope, as I have a direct view of what the engine sensors are doing and can apply that to the VE tables.
Appreciate the help!
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
Street Lethal
Sep 7, 2015 01:09 PM
