Fuel pump replaced! (correctly)
Old Nov 17, 2009 | 07:55 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Just replaced the stock fuel pump with a higher volume pump. I used the pump in this link.
https://www.thirdgen.org/forums/tbi/...fuel-pump.html
What a difference in drivability! Granted my old pump was only pumping 7.5 psi and the new is at 11.5 plus the potential additional volume.
I spent the time to drop the exhaust, rear-end, and tank to do the job the right way (4.5 hours). This project proved to be WAY easier than I would have thought using a floor jack, jack stands, and hand tools (for the most part)! So any one else thinking about doing their pump themselves by dropping the tank I highly recommend doing so.
Thanks for this board and the help I received,
Jono
Old Nov 18, 2009 | 05:16 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Fuel pump replaced! (correctly)
Good job!
I actually prefer changing the fuel pump on these cars then the front springs
Old Nov 19, 2009 | 10:36 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Good to know this is managable, want to move to a TPI pump a 2.0 Bar FPR.
Old Nov 24, 2009 | 01:59 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I did it the right way with a friend. It took us about 2 days taking our time. We probably worked about 3 - 4 hrs each day with a few beers mixed in.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
