Finally got the maro back on the road , with the 383tbi,but having drivability issues
Old Nov 30, 2009 | 09:14 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Ok its a 383tbi , with stock 350tbi heads , and http://www.compperformancegroupstore...ry_Code=HFTXFI
It sputters quite a bit when accelerating , i think the timing is off , what should base timing be for this cam ? Also i am yet to set the valves since break in . Any advice or helpful hints would be appreciated
Old Nov 30, 2009 | 10:21 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Finally got the maro back on the road , with the 383tbi,but having drivability is
has anyone burned a chip for it? base timing should be 0* timing is adjusted in the ecm.
Old Dec 1, 2009 | 07:42 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
It has the stock chip . I pulled this motor out of another camaro of mine , and it ran good , pulled hard , but now it kinda sputters alot .
Old Dec 1, 2009 | 10:00 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
tyler
You have a lot of work to get this combo going.
1) ECM - what is the state of your ECM - e.i. stock (1227846?) with factory EPROM? Please provide service number and BCC.
2) Fuel system - what is your fuel pressure and injector size? Any modification to TB?
3) Intake manifold - factory or AL aftermarket.
4) Exhaust system - factory or modified?
5) Cam shaft 208/217 with 113 LSA 252XFI H13 (nice split duration cam)
All of the above will require substantial VE and SA table work (assuming 305 to 383 swap). So, take your time list details for all the above as a starting point.
//RF
jhawkeye
May 25, 2022 06:33 PM
Fast355
Dec 2, 2016 06:33 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
