Vortec to TBI using GMPP Intake Question
Old May 9, 2010 | 10:10 PM
squirrel's Avatar
As stated above setup, where do I run the water bypass? There is a 5/8 hole to the left of the T-Stat housing can I go from this point to the water pump, which is also a 5/8 hole, OR, do I go from the water pump to the hole in front of intake, almost, below the T-Stat housing. Need help here, at the point of putting water in and fire-up Thanks
Old May 10, 2010 | 08:31 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: Vortec to TBI using GMPP Intake Question
I did not have to run a bypass on my e-tecs(vortec style bolt pattern heads) using the GMPP vortec intake manifold. I think you needed to on some other types of manifolds like edelbrocks.
Here is a link to where it should go if needed.
http://www.camaroperformers.com/cama.../photo_08.html
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
