On my 89 camaro is my ignition timing computer controlled
Car: 1991 Camaro
Engine: 5.0 L03
Axle/Gears: 3.73 i think
Re: On my 89 camaro is my ignition timing computer controlled
easy way to find out is hook up a timing light to the number 1 spark plug wire,,, start the engine..if you don't see your timing anywhere near the the timing tab..then hook up to spark plug wire 6 and see if it shows up..if it does it's computer controlled.. in which case you need to locate the bypass wire and disconnect it before you set your base timing..or i guess you could always leave the timing light hooked up to the number 6 wire and set the timing that way
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: gone
Transmission: gone
Axle/Gears: gone
you have to disconnent the electronic timing connector then you can manually set the timing at idle, it is then computer adjusted after you reconnect the connector
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
YES , you need to disconnect the dist and set the initial timing from there .I don't know how to do it on an 89 but on my 84 I just unplug the 4 wire plug on the dist.
Car: 1991 Camaro
Engine: 5.0 L03
oops i posted the wrong word lol " set the timing that way" shoulda been "check the timing that way"
I've noticed that when i disconnect the bypass wire to set the base timing,,and then reconnect it,,reset the ecm code,,and then connect the timing light to No. 6 plug wire that the timing will be right at whatever is set in the spark table for that RPM and map reading... that's what i meant by the statement above..sorry for the word typo :-)
Ghettobird52
Jul 5, 2024 11:18 PM
9192camaro
16
Feb 3, 2019 12:21 AM
