am i getting enought fuel?
Old Aug 24, 2010 | 02:09 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
i have a 1990 rs camaro that came with a 305 tbi and i swapped it out with a 350 and but the original tbi back on. i dont believe it is getting enough fuel. can i swap out the injectors with some 55 lbs/hr ones? or can i not do that? (the originally had 45 lbs/hr)
Old Aug 24, 2010 | 02:33 PM
Ronny's Avatar
Re: am i getting enought fuel?
That or run TPI pump and increase FP with stiffer spring..
Old Aug 25, 2010 | 03:44 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Your stock TBI came with #55's from the factory.
As Ronny suggested, higher fuel pressure or "biggher" injectors will increase fuel delivery.
It is mandatory to adjust some numbers in the bin wen changing fuel delivery, EBL would be the best option for this purpose.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
