tbi fuel system
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
tbi fuel system
Hey Everybody!
Long time no talk, well the weathers finally not scorching outside so I am about to make use of some brand new parts. I have some fresh 55lb injectors, and the fuel pressure male-female hardware. My question is with the metal valve looking piece do you screw the actuall gauge into the side of this male-female threaded valve? Also where can I get just the gauge?
Car: check
Engine: check
Transmission: check
Re: tbi fuel system
I'm a little confused by your question. On the stock TBI systems there isn't a place to connect a fuel pressure gauge line. Need to open the larger of the two hoses that are between the frame and the engine. And place an adapter there to connect the FP gauge.
RBob.
RBob.
Car: 91 rs
Engine: tbi 350
Re: tbi fuel system
Ahh, I see...
Thank you for not letting me make a mess! But I was kind of hoping you would say autozone or somthing for the guage.
Thank you for not letting me make a mess! But I was kind of hoping you would say autozone or somthing for the guage. Supreme Member
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: tbi fuel system
they sell a fitting to replace the stock throttle bod fuel fittings where you can put a gauge in. im goign to do that when i install my new throttle body i like making things easy.
92camaroJoe
Aug 13, 2015 06:07 AM
