LT1 cam in a carb 305, which rockers 1.52s or 1.6s?
Old Oct 12, 2010 | 08:06 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
This is going in an otherwise stock 50k mile 305. Just trying to figure out if 1.6s are overkill for the engine or not. If so, I can get a set of 1.52s.
Also, am I going to need to replace the springs with either? I have a set of stock LT1 springs.
Old Oct 16, 2010 | 07:18 PM
Jack 305's Avatar
Re: LT1 cam in a carb 305, which rockers 1.52s or 1.6s?
If this is a stock motor and the valve springs haven't lost their tension and the rockers are in good shape,then why change,I doubt you'd see much of an improvement using a stock cam with 1.62 rockers
Old Oct 18, 2010 | 11:07 PM
Camrs89's Avatar
Its gonna be a stock bottom end with LT1 cam, lt4 valve springs (if they work...idk??) 1.6 comp cam roller rockers, and edelbrock performer intake, 750 edelbrock carb, and headers.
Also have stock lt1 pushrods too
Old Oct 23, 2010 | 09:57 PM
Camrs89's Avatar
Still looking for a solid answer...
Old Oct 23, 2010 | 11:58 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Lt1/LT4 valve springs don't work the O.D of the springs are to big for the spring pockets. a 750 carbs to big go with a 600cfm carb. 1.6 money better spent elsewhere.
Old Oct 24, 2010 | 09:34 PM
Camrs89's Avatar
I took the 1.6s in on trade, I dont have the stock ones, I was going to use these for my LT1 Camaro but if they would help the 305, Id use them. Or if it will work, take my stock LT1 rocker arms and use them on the 305? Any issues doing this?
Old Oct 24, 2010 | 09:48 PM
FueledSoul's Avatar
If that's the case no reason why you cant run 1.6's the gains will be hardly noticeable at best. you can use the lt1 rockers too if you wish. If you do use the the 1.6 ratios and depending on spring pressures my recommendation is to pin the studs, its cheap insurance and all you need is a few drill bits and some steel rod.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Reborn756
Sep 4, 2015 03:42 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
happyhapka
Aug 15, 2015 04:42 PM
