Favorable Crossfire Thread
Old Mar 14, 2013 | 12:57 AM
  #51
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Favorable Crossfire Thread
Old Jul 28, 2014 | 12:59 PM
  #52
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Anyone know how to build a manometer?
Old Jul 28, 2014 | 03:53 PM
  #53
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Pretty easy really. It is a U-shaped piece of clear tube, you can use vyhnal tubing and a board. I used some clamps to hold it to the board. You stand it straight up and down and fill the tube 1/2 way full of water. Then connect each side to your hoses. Once you get the tube back level, you are balanced.
Old Jul 28, 2014 | 04:22 PM
  #54
KITT1983's Avatar
How big a board to use? how long and big of a hose to use?
Old Jul 28, 2014 | 05:37 PM
  #55
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Here is a digital version I used for work related analysis...
http://www.transcat.com/PDF/477A_cat.pdf
Old Sep 13, 2014 | 10:27 AM
  #56
KITT1983's Avatar
Bump
Old Sep 20, 2014 | 09:35 AM
  #57
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
If still looking... This is one of the better threads I found on the manometer.
http://www.corvetteactioncenter.com/...le-bodies.html
Old Dec 8, 2014 | 03:56 PM
  #58
n8mobiles's Avatar
Car: KITT, Batmobile, Shaguar etc.
Engine: V8 Crossfire
Transmission: automatic
Autostart with a remote alarm, on a crossfire? any problems? Anyone done this? Just checking the experts before hitting a roadblock!
Old Dec 8, 2014 | 07:31 PM
  #59
KITT1983's Avatar
I had my viper 5900 remote starter alarm system since july 2008. And no problems. other that typical alarm false alerts I am going go upgrade to newer viper system. I can control it via smart phone.
Old Dec 8, 2014 | 07:35 PM
  #60
KITT1983's Avatar
I just my renegade manifold today from ecklers firebird cyber monday/ black friday sale. Any body got CFI TBI adjustment tools for sale?
Old Dec 13, 2014 | 05:35 AM
  #61
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Have a Viper 791XV on my 82 KITT replica crossfire Have had it installed since 2006 !!
there was a starting issue,But my audio "tech" guy fixed it.
Only issue is the POS remote draining my AAA batteries
Dave
Old Dec 13, 2014 | 06:32 PM
  #62
tartagliaz28's Avatar
Car: 2013 ZL1 convertible
Engine: 6.2 supercharged
Transmission: 6l90e
I do. you have a pm
Old Dec 13, 2014 | 10:21 PM
  #63
KITT1983's Avatar
Originally Posted by tartagliaz28
I do. you have a pm
Pm sent
Old Dec 23, 2014 | 11:50 AM
  #64
83 CrossfireZ28's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L 305 Cross-Fire Injection
Transmission: 700-R4
Axle/Gears: 3.23 Limited Slip
Did you ever get that manifold installed?
Old Dec 25, 2014 | 06:51 PM
  #65
KITT1983's Avatar
do you mean the renegade?
Old Dec 26, 2014 | 01:43 AM
  #66
Rabble-Rouser's Avatar
Car: 84z28, 2--1983 TA's
Engine: 305 H.O
Transmission: 700r auto
Just traded a vehicle for a 1983 TA with CFI. It was running rather well but is going to require a new engine unless I devote an entire rebuild bottom to top(really not worth salvaging the 305 at this time), my mechanic is in the process of price checking on a good 350, and everything synced up. I will probably keep the 305 if there is no core fee for a later rebuild on a different vehicle.
The shop suggests putting MS on it before buttoning it back together to optimize performance and weed out hiccups. I am curious on what experience people have had and benefits to fine tune the CFI system? I am familiar with computers and programming so it doesn't intimidate. From what I have been researching it seems like a good bet.
Goal. This is going to be a regular driver and long term 'tinker-project'. Not looking for beast power or race stock or going back to complete bare OEM. Thank you!
Old Dec 26, 2014 | 09:08 PM
  #67
Yes, the Renegade.
Old Dec 28, 2014 | 07:53 PM
  #68
KITT1983's Avatar
Look into ebl flash
Old Mar 30, 2016 | 02:43 AM
  #69
AilmentDiavolik's Avatar
Engine: 305 Crossfire Fuel Injection
I know that no one has posted on this thread for a while but, got a question. My Camaro still has the 305 under the CFI. I got my Renegade Intake Manifold (looks beautiful lol), putting in an electric fuel pump, rebuilding the TBI's, going to change all the sensors, replace all the vacuum lines, dual electric fan, getting rid of the cats, and setting the fuel pressure up. Is there anything else that I could do to get a little more power? I was thinking TBI spacers because I found some for cheap, even though a lot of people think that they don't work, but, not sure if it would cause problems with clearance.
Old Mar 30, 2016 | 09:27 AM
  #70
Ronny's Avatar
If I recall the Renegade is a large runner manifold. It may be too large for a 305. But give it a try. As far as clearance it may be OK. I would measure clearance to hood or top of AC assembly.
Cranking up FP presents its own issues. Crank, choke, AE, open loop will all be proportionately richer and fuel mileage will suffer as well as drivability. Cold manifold upping FP will help in drivability but once it goes CL it will be too rich. Up FP is a crutch for getting PE correct and that will work for PE A/F.
Best idea is to learn DIY Prom on that Forum.
I did what you are referring to many years back. It did not turn out well initially. Today I have port fuel on my CF and it was the BEST idea/result for my current set up.
Old Mar 30, 2016 | 09:54 AM
  #71
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Don't forget the exhaust manifolds. Replace the factory 2" units with L69/TPI 2.25".
The spacers may add a tiny bit of throttle response and power.
Old Mar 31, 2016 | 07:10 AM
  #72
KITT1983's Avatar
I just installed the renegade to my 83 cfi
Old Mar 31, 2016 | 10:50 PM
  #73
chazman's Avatar
Axle/Gears: BW 3.45
And...what do you think?
Old Apr 1, 2016 | 12:38 AM
  #74
Ronny, luckily I have someone that's very knowledgeable about vehicles, except the CFI, that is helping me. I'll admit, I don't know much about vehicles so, while he's helping me, he's going to teach me. I would jump head first into it but, have read these systems are VERY touchy. I'm going to let him read your post in hopes we don't run into any headaches. Chazman, the car now has Hedman headers and a Flowmaster exhaust from the previous owner. Once the guy and I start on it, I'm going to have him look everything over to make sure everything is in order. KITT1983, I'd like to know as well what you think about the Renegade. Is there anything else that him and I could run into? Any help would be appreciated. Don't want to be a way from my car for to long.....hahaha
Old Apr 2, 2016 | 05:36 PM
  #75
KITT1983's Avatar
wonderful things
Old Apr 2, 2016 | 05:49 PM
  #76
KITT1983's Avatar
it was designed for a corvette, you will have to fabricate hold down brackets for accessory brackets. and there was some gap issues for the distributor. but a solution was MacGyvered. it has better flow than the stock intake. the porting is a lot better
Old Apr 2, 2016 | 07:06 PM
  #77
KITT1983's Avatar
I am have balancing issues with the tbi's
Old Apr 2, 2016 | 08:42 PM
  #78
82tarecaro's Avatar
What issue are you having? It has been awhile since I did mine, but I remember finding a procedure online, drilling out the factory welds on the TBI's and using a water manometer.
Old Apr 2, 2016 | 08:44 PM
  #79
82tarecaro's Avatar
This guy used to post here a bit, and I used his procedure.
http://www.thecubestudio.com/Crossfi...yBalancing.htm
I built this manometer.
http://www.thecubestudio.com/Crossfi...tManometer.htm
Old Apr 2, 2016 | 08:47 PM
  #80
KITT1983's Avatar
new England weather
Old Apr 2, 2016 | 08:48 PM
  #81
KITT1983's Avatar
thanks
Old Apr 18, 2016 | 04:39 PM
  #82
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Axle/Gears: GM Posi, 3.73
I've had the Renegade on my car for 2 years, need to get it dyno'd so I can measure HP difference.
Old Apr 19, 2016 | 04:56 AM
  #83
KITT1983's Avatar
where is the current picture of your intake ? Current picture of my setup with the new Renegade intake..."
Old May 4, 2016 | 04:57 PM
  #84
gheatly's Avatar
Car: 1982 Z-28
Current engine pic
Old May 6, 2016 | 03:51 AM
  #85
KITT1983's Avatar
Current engine pic
very nice
Old May 21, 2016 | 07:21 PM
  #86
Need to get extra thick valve cover gaskets or shave the underneath off of the ones I'm putting on and make a gasket for the top plate. TBI's have been rebuilt, all new sensors going in, new vacuum lines, and the air cleaner assembly will be powder coated and engine will be detailed.
Old May 25, 2016 | 06:43 AM
  #87
KITT1983's Avatar
what gasket did you use for top plate and valve covers ?
Old May 25, 2016 | 06:56 AM
  #88
KITT1983's Avatar
Old May 25, 2016 | 09:08 AM
  #89
Ronny's Avatar
On top plate I would use "right stuff".... No gasket needed
Old May 25, 2016 | 01:59 PM
  #90
Went to get a gasket for the Renegade thinking that they made one for it but, found out that they didn't. That's really the only thing holding me up til this coming Saturday. The valve cover gaskets are regular but, the VC's have a little part that hangs down that hits the Renegade. Shave that down and it will be good to go. Nice pictures KITT. Ronny, thanks for the advice on "right stuff". Was wondering what the hell I was going to have to do. Don't know much about vehicles so, the guy helping me is teaching me while I do most of the work.
Old May 26, 2016 | 09:26 AM
  #91
Ronny's Avatar
When I ran XRam I don't recall using any sealant or gasket. A small leak may not matter as injectors are spraying on plenum floor anyway and sheared off with velocity. Not the best technology in fueling design there! If you remove the lid I suspect you will see fuel puddling at low corners of plenum. I did.
Old Jul 18, 2016 | 06:54 AM
  #92
KITT1983's Avatar
I just used gasket sealer
Old Sep 11, 2016 | 05:09 AM
  #93
KITT1983's Avatar
I have sent my tbis to rebuilt
Old Jul 12, 2018 | 06:32 PM
  #94
KITT1983's Avatar
Bump
Old Aug 18, 2020 | 12:09 AM
  #95
Been over two years since anyone posted on here. Anyone close to the Eastern Panhandle of West Virginia? I'd like to get a bunch of CFI owners and go for a cruise. Posted that on the CFI group on FB but, nothing yet.
Old Dec 30, 2021 | 07:16 AM
  #96
KITT1983's Avatar
350 build
https://www.airflowresearch.com/180c...zwHv7CjKO99cg0
https://www.summitracing.com/parts/edl-2103
https://www.jegs.com/i/COMP-Cams/249...X9eZ3LZ0LoKuwc
Old Feb 21, 2022 | 09:07 AM
  #97
KITT1983's Avatar
well I ordered the Parts I listed
Old Feb 25, 2022 | 06:03 PM
  #98
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
I have been building and daily driving CFI cars for over 25 years. In addition to being an expert on 82-84 Trans Ams, with almost 30 years of correct restorations, documenting, researching; I am also a known CFI guru. I have a youtube channel dedicated to the LU5 and L83 engines. Link is below 👇
https://youtube.com/channel/UCt0PkN5IuhiZsrP3rTATcEA
Old Feb 25, 2022 | 07:21 PM
  #99
KITT1983's Avatar
hey I know your page and we are friends on facebook
Old Feb 25, 2022 | 07:24 PM
  #100
1983LU5TA's Avatar
Engine: LU5, LSx
hey I know your page we are friends on face book
