CFI flow rate
Old Jan 25, 2011 | 08:11 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
CFI flow rate
Could somone please tell me the the flow rate of stock 305 Crossfire injectors? I have searched for an hour and found nothing but TBI flow rates .
Old Jan 25, 2011 | 09:55 PM
89rs454's Avatar
Car: 1989 SS
Re: CFI flow rate
Are they 55 lb/hr could someone comfirm this?
Old Jan 25, 2011 | 10:11 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Re: CFI flow rate
no, not 55. I believe one is rated at 62 and the other is at 64. The flow rate is staggered due to the fact that fuel is routed thru one TB to the other. I believe drivers side is higher number. Not exactly sure of rates, but I know it is low to mid 60s.
SORRY THAT'S FOR THE 350. Misread engine size. Not sure if 305 had staggered flow rates.
Old Jan 26, 2011 | 06:40 PM
89rs454's Avatar
Car: 1989 SS
Re: CFI flow rate
Will 305 TBI injectors work for a CFI 82 Z28 305? The injectors look the same and the Hp rating is around 165 CFI to 175 Tbi but if it's staggered, will it make a difference? If not, i will just throw an intake and carb on it and be done.
Old Jan 26, 2011 | 07:46 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: CFI flow rate
maybe talk to your local chevy dealer (ask them too look up the original injectors)
Old Jan 27, 2011 | 11:32 AM
Ronny's Avatar
Re: CFI flow rate
stock is plumbed in series. some of us plumbed in parallel. that would allow matched in size.
I am pretty sure this is the case for both CF engines. I would contact FIC injectors and ask what they offer or advice.
Having 2 TBI injectors of same size is not ideal but will get you down the road.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
