is cfi worth anything?
Old Feb 13, 2011 | 03:24 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
I have a lu5 with the cfi system but I keep reading that the cfi is not very good and a lot people convert to a carb setup. My car isnt running because of the fuel pump and has a few vacuum leaks too. Is cfi worth fixing or should I just convert to carbs?
Old Feb 13, 2011 | 05:36 PM
ex-x-fire's Avatar
Re: is cfi worth anything?
CFI is a very reliable set up, very similar to tbi. The intake is restrictive, so to make any power out of it you'll need to port it or replace it w/ something like a renegade intake. On my 84 vette that had cfi, I switched over to single 2bbl. tbi (like the 88-92 tbi camaros), used my stock wiring harness & ecm to run it. Now I can run any 4bbl. type intake w/ a tbi adaptor that will fit under my hood. I switched over about 10yrs ago.
Old Feb 13, 2011 | 08:50 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup basically. they were known to not be the greatest. but thier are people out there who absolutely love them
Old Feb 14, 2011 | 01:28 PM
Car: 1983 Trans Am
Engine: Lu5
Alright thanks for the info. So do carbs give more power and cfi is more about better performance?
Old Feb 14, 2011 | 01:55 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Crossfire is just a really neat and novel version of TBI. I think it is more efficient than a carburetor, but it needs to be properly tuned to get max power and its more difficult to make power with than a carb.
So the REAL question is, what do you want from your car?
If its me, I 'd put a TTA fuel pump in it, tune it up, and run it as is for a while...
Old Feb 14, 2011 | 02:07 PM
Car: 1983 Trans Am
Engine: Lu5
I think that's what I'm going to do. Thanks for the help.
Old Feb 14, 2011 | 08:41 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Certainly, but it depends on how much you like to work on your car. It takes some effort to get it running right when you buy the car. Usually, all of the vacuum lines need to be replaced and the throttle bodies need to be rebuilt (the throttle shaft bushings wear out). Once you get it running well, its only a matter of maintaining it.
I would suggest buying a 1982 Chevrolet Camaro Shop Manual. These were used as reference books at the dealership when the mechanics were working on the cars. There is a lot of good info and once you read through it, the CFI is much easier to understand. It's really not much different from a single 2-bbl TBI, but it looks a whole lot cooler!
There are also guys out there still supporting CFI with aftermarket parts, so you can modify your system to handle as much power as any of the 2-bbl TBI guys. I just installed a new aftermarket CFI intake. Before the intake swap, the engine made 240 RWHP and 270 ft lbs of torque.
Here is a pic of my modified CFI:
Old Feb 15, 2011 | 10:46 AM
Car: 1983 Trans Am
Engine: Lu5
Ok thank you. gheatly where did you get the fuel line between the throttle bodies with the guage on it?
Old Feb 15, 2011 | 11:57 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Gheatly, that is a great looking setup! I love that cross ram intake you used. Does it allow you to use the factory air cleaner to hook to the hood?
jolly, that is the setup I would try to emulate if I were you. Just put yours back to stock good working condition first, and then work your way up. Its really a cool setup.
Old Feb 15, 2011 | 02:01 PM
Car: 1983 Trans Am
Engine: Lu5
Yea that is going to be my new goal, to get my setup like that. I cant wait to get started and get my T/A back on the road
Old Feb 15, 2011 | 05:50 PM
gheatly's Avatar
Car: 1982 Z-28
The company is called Dynamic Crossfire Solutions (DCS). They sell several parts including the polished SS fuel line with fuel pressure gauge and the Renegade intake. They sell several other parts you might find useful in addition to rebuilding and boring throttle bodies.
The Renegade cross-ram fits within the form of the stock crossfire intake, so everything bolts up. The stock air filter housing does fit to the hood. Unfortunately, the HAM board I have does not have the ability to control the hood flapper solenoid. I am planning in using a throttle actuated nitrous switch when I get around to it.
Get the shop manual - you will be glad you did. Start by doing repair and replace of old parts. If your car is high mileage, I would get throttle body bushings replaced. Runs around $125 IIRC. Will help maintain a stable idle.
Old Feb 15, 2011 | 10:12 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I swapped my originally carbed '82 z28 to CFI back in
'94(tried it in '93 too,but didn't do it right-ran like crap
LOL)tried again in '94 with a complete '84 vette 350
after a few glitches got it running good,then in '95
modified for a major horspower increase
been running great and very reliable ever since
BTW most of the major horspower increase was from
modification and porting of the intake manifold
Old Feb 16, 2011 | 01:02 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Here is the website for dynamic:
http://crossfireinjection.net/
Its got me thinking about using a renegade on my TBI car, and replacing my single TBI with two one barrel units. Hmmm.......
Old Feb 16, 2011 | 11:06 AM
gheatly's Avatar
Car: 1982 Z-28
I seriously thought about getting another Renegade and converting my '69 Camaro to Crossfire since I have extra parts lying around. Tough decision, but went LS instead for more,easier horsepower. I still think a '69 with a good, modified Crossfire system would be awesome.
I didn't want to put the link to DCS; didn't know if it was allowed by forum rules.
Old Feb 16, 2011 | 11:15 AM
Ronny's Avatar
If you are a user of EBL a better safer idea is to use it to activate solenoids. you can set for MPH and RPM paramenters. I am at 3200 rpms and 35 MPH. I have run N20 now for one season.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 16, 2011 | 11:29 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
I don't think posting a link to more parts or tech is a no-no; its helping people out and that's what this place is all about.
I think using a crossfire TBI system anywhere an original cross ram style carburetor setup was used (like vintage racing stuff) would be really, really cool.
Old Feb 16, 2011 | 11:32 AM
Ronny's Avatar
It has its CFM limitations. There is an extrude hone available at significant cost to max the CFM. That being done with a 283 CID would be cool. IMO.
Old Feb 16, 2011 | 12:28 PM
Car: 1983 Trans Am
Engine: Lu5
Should I get the 82 camaro shop manual even though I have an 83 T/A? I know they are very similar and had the same engine and cfi setup but would the manual help me with other things besides that?
Old Feb 16, 2011 | 12:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When using the HAM with an EBL set up you can use pin BLK-16. That pin is activated when the ECM goes into PE mode (WOT mode). It will pull low when activated. Can use that to drive a relay that then drives the solenoid.
RBob.
Old Feb 16, 2011 | 07:46 PM
gheatly's Avatar
Car: 1982 Z-28
Ronny - I'm not planning on using the switch for N20, only to activate the hood flapper soleniod. I know it's juvenile, but those flaps opening up are freakin' cool!
Jollythought - The Pontiac manual may be harder to find, but I would get one if you can. The manual covers everything about the car, so there will be other stuff you want. If you can't find one, go for the Camaro manual. The crossfire and other engine stuff should all be the same.
RBob - That is great to know. IIRC, when Ken at Speedtronics assembled my HAM, some resistor that was required for the flapper solenoid circuit was no longer available, so he said that it wouldn't work. What do you mean by BLK 16? I looked at EBL pinout and on the black connector C16 is bat + and D16 is INJ #1 driver.
Old Feb 17, 2011 | 03:57 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Juvenile, shmuvenile. Those flaps opening are probably my favorite part of having a CFI!
Old Feb 18, 2011 | 07:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It would be pin 16 of the black connector to the CFI harness. It is pin C1 on the ECM side.
If the resistance of the solenoid is 60 ohms or more, can drive it directly from the ECM. However, being a solenoid to open the flaps it is likely lower in resistance to provide more mechanical power. So I mentioned the relay to be on the safe side.
RBob.
Old Feb 22, 2011 | 05:33 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
the value of your KARR is in the eye of the beholder
I have the 1983 firebird shop manual
Old Feb 22, 2011 | 07:23 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
So, how much to reproduce it so that we can have copies?
Old Feb 22, 2011 | 07:56 PM
KITT1983's Avatar
http://cgi.ebay.com/ebaymotors/1983-...sQ5fLiterature
this is the same guy I bought it from back in 2008
Old Feb 22, 2011 | 08:27 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Thanks for that. Its now marked in my list of stuff to get next payday!
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
