Help ! 383 doesnt work...
Old Mar 31, 2011 | 04:40 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
My new 383 doesn´t start. I think, the afr is too rich. I am going with a 454 BBC TBI, 80´injectors @20 PSI and turbocity´s vacuum fuel pressure regulator (9-20 PSI). My ECM works with the EBL. I think, the BIN is correctly. I was starting with the BIN from the 89´caprice with L05-engine, then, i changed the BPC-cells in BPC-BPC VS VAC, BST-BPC VS BOOST, disabled the EGR, and multiplied the cells in AE-TPS PW and AE-MAP PW with the factor 0.763 (61´injectors divided by 80´injecors). Everything to get a simply baseline-bin.
What can i do ? Which injectors at how much pressure do you use on your 383 stroker ??
Old Mar 31, 2011 | 06:47 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Help ! 383 doesnt work...
Ya too much fuel, we are talkin' EBL_F_2018 right?
I would start with the VRfpr (BPC's all at 90) disabled (plug the TB line) to start for consistency.
Then knock the 400-500 rpm VE's in half all the way across.
See if she lights up.
Old Apr 1, 2011 | 12:17 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Yes, we are talking about the 18´BIN. Ok guys, to go with 80´injetors @13 PSI was the right way. Engine runs great.
Old Apr 1, 2011 | 03:45 PM
xch3no2's Avatar
Transmission: TH400
That's good news, the 90BPC I mentioned was for 20 psi.
I might have chosen smaller injectors to use with more pressure, but that's just me. You might yet find good use for the big injectors at high RPM.
Keep us posted.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
