TBI Fuel Problem
Old Jun 17, 2011 | 11:55 PM
RicerEater78's Avatar
TBI Fuel Problem
i have recently bought an 89 firebird formula that had the original 305 tbi taken out and reused all of the parts on a 350 long block. the car runs fine going down the road, but at idle it drops to about 600 rpm and doesnt stay in one spot. it will slow down a bit, pick back up, and repeat. at idle you can also smell gas in the ehxaust. the only problem i could think of that would cause that would be bad o2 sensors. can i get confirmation on that or maybe any other ideas? thanks in advance
Old Jun 17, 2011 | 11:57 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: TBI Fuel Problem
poorly adjusted Throttle position sensor. I was battling a problem like this for awhile. I changed the whole throttle body out with a replcaement that came with a tps, IAC, injectors etc. But before I did that I tried two different TPS and IAC and still had it. I think it was possibly a leaky injector seal and bad injector. But I also changed the intake gasket at the same time too. one of those things fixed it..what exactly..I dunno. Try and adjust your TPS. Thier is a thread here somewhere about it do a and you'll find it
Old Jun 18, 2011 | 12:00 AM
ah ok. ill try it out. also, if i tap the gas at all at idle itll kill the motor. same problem?
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
