vacuum routing ? for map and brake booster on new manifold
Old Aug 11, 2011 | 11:45 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Can I run the brake booster and map sensor off the same vacum port or do they have to be seperate? Im installing the weiand 7525 and it doesnt have the factory brake booster port so Im going to use the only port it has at the rear of the manifold. Can the map sensor be plugged into one of ports on the TB or does it need some special placement of the port?
thx
Old Aug 11, 2011 | 05:53 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: vacuum routing ? for map and brake booster on new manifold
Run the MAP sensor from the rear port on the TB.
Old Aug 11, 2011 | 06:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
IIRC - there's a brake booster vacuum port on the TBI unit - all the TBI cars connect the brake booster to that do they not?
Old Aug 12, 2011 | 05:25 PM
iggy1991's Avatar
no there is no booster port on the TB its a seperate fitting on the manifold.
Thank you I did just what you said about putting the map on the rear TB port, it made sense when I was looking at it before I checked back and read this.
1992 Trans Am
May 10, 2023 07:19 PM
cstrobel65
Aug 15, 2015 10:19 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
