INTAKE MANIFOLD PORTING
Old Oct 7, 2011 | 08:39 PM
Sttn89's Avatar
Car: 89 caprice
Engine: 350 650 dp on roids
Transmission: 700r
Would porting the stock TBI manifold be worth anything?
Old Oct 7, 2011 | 09:02 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: INTAKE MANIFOLD PORTING
The more air you move the more power you can make. I think its worth something, but changing your cylinder heads will yield more, but upgrading the intake would not hurt.
Old Oct 7, 2011 | 09:33 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
Any idea on were I can search to find some info on how to get it done?
Old Oct 8, 2011 | 11:56 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
If the engine makes less then 270fwhp leave it alone including the TB, otherwise you will end up disappointed.
Though if you like playing with your engine and have nothing better to do, then do it. It sure can be fun.
Old Oct 15, 2011 | 09:00 AM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
Any ideas on how it can b done?Do i port all the runners or can i gasket match??
Old Oct 15, 2011 | 09:23 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Yes, it will be worth more RPM. The problem though is that if your not cammed for more RPM, then as was already mentioned you will in fact be disappointed because your going to lose a little bit of torque down low without realizing the benefit of your port work because your running the very same camshaft. In my opinion, don't concentrate on increasing the overall size of your ports, just focus on velocity porting them. This will speed up the same amount of air being pulled in without sacrificing torque. Meaning, make the pathway as straightforward as possible, with no obstructions, and remember that the fastest path between two points is a straight line (hint hint)....
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Jake_92RS
Aug 11, 2015 10:39 AM
