1989 camaro fuel pump relay
Car: 1998 Trans Am/1992 Camaro RS
Engine: LS1/5.0L TBI
Transmission: 4L60E700r4
Axle/Gears: 3.23/2.73
hey im getting a 1989 camaro rs with tbi and the PO hadcut the connector off for the fuel pump relay and put a different relay in. can you guys show the the relay im suoposed to you and that the wires should be please, thanks
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 1989 camaro fuel pump relay
This is the pigtail you need
http://tpiparts.net/inc/sdetail/10962/4571
or this one from NAPA, but you'll have to figure out the wiring (they're all white)
http://www.napaonline.com/Catalog/Ca...RecType%3aA%29
Relay is available at NAPA also, and at TPI Parts
http://tpiparts.net/inc/sdetail/10959/1477
92camaroJoe
Aug 13, 2015 06:07 AM
