Which one first?? Heads, EBL Flash, Gear ratio
Old Dec 30, 2011 | 12:42 AM
ericamaro89's Avatar
Car: 1989 Camaro RS
Engine: LO3 305 TBI
Transmission: 700-R4
For a 1989 Camaro RS with 305 TBI only upgrades are short headers and flowmaster.
So I was really wanting to get a new cam, after listening to other people saying I should leave cam till last. (I don't if thats good)
Now that I have some money saved up which should I do first?
Port stock 305 Heads?
Order and install EBL flash? OR..
Change my gear ratio to 3.73?
Comments and recommendations highly appreciated.
Old Dec 30, 2011 | 09:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Which one first?? Heads, EBL Flash, Gear ratio
I wouldn't go with 3.73 gears unless the engine can rev more. Going with 3.23 or 3.42 gears would be better. The V6 cars used those ratios, so easy to get. And get the speedometer gears too (from tranny).
If the heads are off I'd do a cam at the same time. No sense tearing it down twice.
Will also need a better fuel pump once the heads/cam are done. Along with increased fuel pressure or larger injectors to support the additional HP.
Once the heads/cam are done tuning is going to be required. So maybe a good order is:
gears
fuel pump (TPI or a 190 LPH)
EBL Flash
injectors or adjustable FPR
heads & cam
RBob.
Old Jan 1, 2012 | 12:40 AM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
i would first buy the ebl flash which was what i did wen i had a 305 (even with stock muffler it sounded louder and ran better after a few tuning runs) i then bought an exhaust so my order was 1.ebl 2.exhaust 3.350 swap but do the ebl swap first its one of those upgrades thats better to do early (wen u got the money) then later wen ur car has new parts but runs like crap because it doesn't have a decent tune
Old Jan 5, 2012 | 07:55 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Getting very familiar with your tuning equipment and software is always a good idea before you start changing things around with mods.
MustangBeater20
Oct 29, 2022 09:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
beast94
Aug 20, 2015 06:44 AM
