tbi to carb swap question
Old Jan 7, 2012 | 03:59 AM
Rondeezzee310's Avatar
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Im thinking of swapping to a carb an was wondering if ill need to change aany linkage where the gas pedal and transmission cable connects at the tbi to convert it to carb.
Old Jan 7, 2012 | 05:42 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: tbi to carb swap question
yes you will need all these parts from a Q jet car
why would you do this?
tbi is a little better on fuel and easier starts especially when cold and so much easier to work on than a carburetor which are commonly problematic and worn out and other issues
i used to swear by carb too, but now that ive owned a tbi vehicle it is so much better easier than carbs
night and day difference better
to convert to carb you would have to drop the tank and swap senders,
remove ECM and wiring
convert to carb linkages and parts, and intake manufold and a carb 87-89 intake is unique to those three years only if you retain the 87 up heads anyways
and there are some other issues too, including that you would need to find and install a large cap HEI distrib
and so on
Old Jan 7, 2012 | 12:26 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Since you live in LA the swap from TBI to Carb will never pass bi annual CA Smog Check. You will not be able to register in CA.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
