LO3 effective mods
Old Feb 9, 2012 | 09:29 PM
Guest
Guest
Posts: n/a
LO3 effective mods
Could anyone give me advice on the most effective mods for an LO3? Its a 91 RS. I am the only one in my family who got the "car gene" and have no one else to tell me this stuff. For a stock LO3, what would be the best cam? What about headers? And does anyone know of a chip that will work for these things?
Old Feb 9, 2012 | 09:55 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: LO3 effective mods
Do some searches first, ultimate tbi mods is a good one to look up, im running hooker shorty headers, imo headers and exhaust should come first, then ultimate tbi mods, including fuel pressure regulator, then rear gear change, then you can get into cam options and tuning
Old Feb 10, 2012 | 12:20 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
read the cardomain and have a nice day........
Old Feb 10, 2012 | 04:39 PM
one92rs's Avatar
Car: SOLD!!!!!
yes look at robertfranks cardomain site. he is pimping out awsome info.
Old Feb 10, 2012 | 05:23 PM
well I've been there and done that so I guess I might know a little bit lol.
Old Feb 11, 2012 | 05:47 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Since effective is mentioned, you can skip the ultimate tbi mods from the list, for a long way.
Unrestricted air cleaner, full exhaust and gears is the no brainer part, if you play with the fuel pressure I would suggest a coustom chip at least.
If you add a cam, like LT1 or similar, fueling set up and some serious tuning become mandatory.
Old Feb 11, 2012 | 08:41 PM
one92rs's Avatar
Car: SOLD!!!!!
from doing all the other mods the only time i really noticed the ultimate tbi mod helping was on the freeway. i think it is a good free mod of time.
Old Feb 11, 2012 | 10:30 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's something that you can do at home with a timing light. Advance your timing between 3* and 6*advanced. Mine runs great at 4* advanced.Do some reading with the search option and familiarize yourself with the process. I think it made a nice difference with my throttle response.
After that its as "tomas1976" said the basics with opening up the intake and exhaust then it really depends on what your goals are when it comes to picking a rear end. Mine is a DD streetcar so I stayed with the 10 bolt and went from a 2.73 open differential to a 3.42 ratio and Eaton posi. with support cover. The rear end work is what really woke the car up.
Old Feb 14, 2012 | 10:30 PM
Guest
Guest
Posts: n/a
Thanks a million guys. I'll definitely checkout the timing and robertfrank, you've got a damn good ride. Where'd you get the SS badging? Sweetest thirdgen SS I've seen.
Old Feb 15, 2012 | 12:46 AM
Thank you sir,lol. I made the emblems from some stock S10 emblems. I cut off the "10's" and made a slight bevel so the other S could be placed on using JB Quick. I taped off the bowtie and letters, painted them with satin black paint/with clear and put them on.
Old Feb 15, 2012 | 03:44 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
robert whats going on my old friend i see the ride is still looking good to bad i cant say that about the driver haha. and jayhawk there are some things around to do with your car but you have all the info you need on this site. lots of knowledge on here goodluck
Old Feb 15, 2012 | 10:44 PM
Haha funny guy, lol. What's up Rock? I need to update the cardomain with some new pics. I've changed a couple things on the car and I need to put up some new info.
Old Feb 16, 2012 | 05:57 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
As with the LG4, GM chose to lower the HP of the lo3 by choking the airflow in and out of the engine. Simply switching to a stock L98 TPI exhaust (3" vs. 2.25") and using an L69 dual snorkel air cleaner assembly (with a K&N filter) can be worth over 30hp. Going to headers and a performance 3" cat back will give you even more. You also have things like chips, under drive pulleys, and other items that work well to add more HP.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Damon
Sep 26, 2015 04:29 PM
